Spots on my ipod
Re: Spots on my ipod
Those look like Irradiance Map artifacts. Without seeing your settings, you've got probably 3 different options. The first is to increase your IM settings, and in this case subdivisions probably won't help, so you'll need to increase your max rate. The second is to use Detail Enhancement, which is probably the best route. The default settings should work for you with the exception of Radius, which I would put much smaller. And the third option is to just go all the way to DMC. In this case, DMC probably wouldn't be too bad, since its a simple scene and it wouldn't take too long.Damien Alomar<br />Generally Cool Dude
