DR file size issue - possible solution
  • DR file size issue - possible solution
    I don't know if this is a good workaround or not.
    I just managed to get a 40MB file out to the DR slaves by taking the most complex NURBS stuff and putting them on layers - and then meshing each one by trial and error.
    It might be something to do with trying to convert the NURBS and sending the mesh - a straight mesh might work fine.
    I have some NURBS going too.
    Good luck. Glenn
    Re: DR file size issue - possible solution
    Converting nurbs to mesh will decrease the ram usage, if you have ram shortage that will help you, but originally that has nothing with DR. I remember working with 90 MB interior nurbs models in DR.
      i meant turning to bmps - and maybe its Bongo - sorry v. tired ...
        well it seems to crap out approx. 500K polygons..
        the joy of Bongo and aircraft interiors...
        turned the jpgs to bmps it helps - but not much... maybe ut is RAM - pure and simple....
