QM Settings problem
  • QM Settings problem
    Hi, trying to set Q M settings.... It seems really burned:
    This is the test with Micha Settings.
    Thank you
    Zooropa
    Re: QM Settings problem
    We're going to need more information than that. And is the result just by changing settings? or has the material or scene changed slightly?
      Hey Dalomar, the materials and the scene are the same. The only difference is..visopt file.
      Can I send you the Visopt?
      Thanks Zooropa
        Visopt Settings:
        Please Help
        Thank you Dalomar!
        Zooropa
          There really isn't much there that would seam to cause a change like that. The only thing that might really have that kind of affect would be the Max Depth. At the default its 2 instead of 5.
            I tried with 2 (Max Depth)...same result:
            What happen?
            Thx
            Zooropa
              Anyone knows why QMC does this???
              I read at Vfr Book about the quality colors and high def of this mode. But always I try with this...the image looks really burned.
              Thank you.
              Zooropa
                I don't know why there was a change, but in general settings in the QMC Sampler will only adjust the quality of the image as a whole. This is almost to specific for a change in the QMC sampler.
                  But, for example, If I gave my file to you, what do you think your vray will do?
                  Can we try?
                  I only want to know if this happen only to me or not.
                  Thx
                  Zooropa
                    Still trying....this is a render with gi_qmc_lc_medium.visopt (Visopts from vfr). I loaded Michas Starter kit HDRI
                    Without Hdri files:
                    I discover.. that something with the Hdri...changes everything...
                    Could be that QMC and HDRI work different than IMap and Hdri???
                    Thanks a lot guys
                    Zooropa
                      Still trying....but not finding realistic. How can this happen ..the results are far away from the IMap+ Light Cache results.
                      Thx
                      Zooropa
                        Check gamma correction and color mapping.
                          Excuse me Micha...Gamma correction inside Color mapping?? or this is another parameter?
                          Thank you a lot!
                          Zooropa
                            Gamma correction at the global switches - very important!!!
                            • #15
                              MICHA YOU ARE A GENIUS! THANKS A LOT
                              I didn't know about Gamma Correction, Im trying to introduce my self in this parameter. I can't find at Spot3d anything. I only know that higher numbers = more light!
                              I read about this Gamma Correction at this forum but all the data seems to be for advancers.
                              Thanks a lot a lot.
                              Zooropa
