What Would Cause This?
  • What Would Cause This?
    The brushed metal material is the same for every object. However, on the sloped section and rolled section of the hood, it gets very noisy. How can this be fixed? See image.
    Re: What Would Cause This?
    Problem solved. Somehow, two surfaces were stacked on the same plane. Once I deleted one of them, the problem went away.
      Yea, V-Ray has problems with coplanar faces. It can't determine what its supposed to be and light sometimes gets trapped in between them. If you change Secondary Ray Bias to .001 then that will help with these issues sometimes. Its still a practice you should avoid if possible.
