Translucent Material (2.Questions)
  • Translucent Material (2.Questions)
    1. Do you know how can I match the color of this 2. They are the same, but...SSS materials looks darker! I know that i can change the light multiplier, but It will affect my whole scene.
    2. Look this reflection! Its Weird!!!! How can i correct this problem?
    Thannks a lot!
    Zooropa
    Re: Translucent Material (2.Questions)
    It's a problem for me too, that if I have a plastic material that looks good and I add a SSS effect, that it looks much darker, because the diffuse layer must be set at an transparency. My workaround - use the acolor and the multiplier instead the standard color option.
    http://asgvis.com/index.php?option=c...d=30&Itemid=55 (glass material - at the text end)
      am I doing right? Doesn't look so different from the other one.
      What do you think Micha?
      Thanks
      Zooropa
        Right, difficult to see a difference.
          I'm trying to get this kind of translucent plastic:
          This is my best result till now:
          Thank you!
          Zooropa
            I would use a glass material and set reflection/refraction glossiness at low values. For example try 0.7 (for refraction you could try 0.. Also you could add an emitter layer at high transparency and play with the intensity. A very light glow can be usefull. Or/and add a diffuse layer and play with the transparency.
              Thanks Micha! It's a shame...beacuse of the time I couldn't do it in Vray. Thanks a lot anyway!
              Zooropa
