Create a sun light - script help needed
  • Create a sun light - script help needed
    I'm not happy with the Rhino sunlight command, because the placement isn't the best. Today I got the idea to create my own button, but something dosn't work. Here my raw button script, that show the idea:
    _DirectionalLight
    _sellast
    _visMakeSunLight
    The problem is, that sellast dosn't wait for the creation of the directional light. Doe's anybody know, how I can solve the problem? Damien?
    Ciao,
    Micha
    Re: Create a sun light - script help needed
    You're gonna kick yourself for this one Micha
    _DirectionalLight _Pause _Pause
    _sellast
    _visMakeSunLight
      visMakeSunLight?!?!? Awesome! Is there a way we can "un-make" a sunlight? I frequently go back & forth between physical & default camera setups so this would be pretty nifty if I could use the same directional light.
        Here you go. This basically replaces the Directional Light with a new one. There's no way to test whether its really a sunlight, but its close enough. Just save this in a location that you won't move around, then drag and drop onto a running instance of Rhino. This adds the alias "visSunToDir" and will run the script for you. Enjoy
        http://www.box.net/shared/iskhgjed99
          Thank you Damien, both works nice.
            Your welcome
              Sah-weet!
