Seting up Z-depth
  • Seting up Z-depth
    Hi everyone
    I search whole forum and I can't find it...
    How to set up z-depth channel?
    When I add it and render i have whole black channel.
    Do i need physical camera for this?
    I have script for calculate maximum and minimum z-depth, bat what do i have to do with this?
    Please help
    http://www.botak.me/blog
    Re: Seting up Z-depth
    It's a bug of the latest release that it dosn't work.
      ok thank's
        Yea, we got that bug...I don't know when that really showed up b/c it wasn't when we first introduced the additional render channels...I wrote the set z depth script after we got those channels in there, so something else threw it off. Something else to take a look at.
          In which version z-depth is correct?
          Can I install lowest verssion and render only z-depth?
            You could do that (it worked in 1.01.6, but you might try using the test command TestShowZBuffer. This will pop up a window that has what would be the z depth channel based on the extents of the geometry in the viewport itself. Its not going to be as pretty as the rendered z-depth channel, but it may be a better alternative than uninstalling and reinstalling over and over. Just screen cap it after you've run the command. There also may be version issues using a scene that was prepared in the new version of V-Ray with the old version, but since you just need the geometry for the z depth channel you could export a temporary file without any of our plugin information.
              I tried with "TestShowZBuffer" but with image 7000x5000px this dont work good.
              I have to instal earliest version.
              Can You tell me is this version somwhere on yours server?
              P.S.
              Maybe You now when Z-Depth will be fixed?
                Sorry excuse me my ignorance but, what the Z depth channel for? and what is it basically? I opened the TestShowZBuffer and it pop up a window of the file like in negative well not negative like in black and white but with gradients, can someone explain me what is it for? thanks!
                Regards,
                  Read this
                  http://luckymutt.net/tutorials/dof.aspx
                  but photospop is not the best software for this
                    Originally posted by botak
                    Read this
                    ... but this seems to be a great tool:
                    http://www.dofpro.com/
                      Both Micha and botak, thanks for the information! I think I understood, so it means that when I paste the image with the Zdepth channel when applying the effect I will be able to blur the image as if I have the render with a physical camera in rhino, but instead of that I can do that with the Zdepth, is that correct?
                      Regards!
                        Right, the DOF per postwork is faster, but maybe not so perfect. Also you can use the z-depth map for fog effects.
                          P.S.
                          Damien, can you tell any news? It's missed here too.
