saving sunlight, z-depth?
  • saving sunlight, z-depth?
    at the college where i'm teaching vfr we don't have the icons in the sunlight system for saving and loading settings, and z-depth still doesn't work, which i thought was a build issue. i thought this was an issue with using an older vfr build, but they finally upgraded to 01.05.29 .... still not working. any thoughts about what they're doing wrong? is it possible they're using an older version of the RDK?
    thanks!
    emil mertzel
    vray4rhinoWiki
    Lookinglass Architecture and Design
    Re: saving sunlight, z-depth?
    It sounds like something went wrong with the installation as all of those things should be there and should be functioning properly. Make sure that Rhino is completely shut down and that there are no "phantom" Rhino tasks still running. The best way to do this is simply to restart your computer, then without starting Rhino, run the V-Ray installer.
      i'll have them give it a try. unfortunately the way the labs are set up it's really hard to debug this stuff.
      Thanks!
      emil mertzel
      vray4rhinoWiki
        Hi
        The save and load button are on the new RDK. So you have to download the new version.
        Best
        Fernando
