Rendering an animation using Vray in Bongo
  • Rendering an animation using Vray in Bongo
    I just downloaded Bongo for rhino and have been messing around with animations. I have been able to render using the default rhino renderer, but i cant see how to select vray to render my animation. Could some one please explain how this can be done?
    Thanks in advance
    Simple setting
    In the Bongo Render Animation dialog, look under the Output : Target Render section and change the default. Its typically set at "Viewport Display" so change that to "V-Ray for Rhino."
    If you haven't already, be sure to also set your Rhino default render to V-Ray in the top menu. That is under Render-->Current Renderer-->V-Ray for Rhino.
