How to exclude object from casting shadow
  • How to exclude object from casting shadow
    Is it possible to exclude objects from light and casting shadow
    Re: How to exclude object from casting shadow
    You can turn off the global shadow, but not per object.
    Best
      There is a way for simple objects like surfaces and walls or background images ...
      http://forum.asgvis.com/index.php?topic=3782.0
      "If the material is assigned to "Back", than lights from outside comes through the wall ..."
      ... it means, no shadow. I doesn't work for polysurfaces, because the front surface will not be visible. It's only good for surfaces, where the backface is visible.
