Using V-Ray Raw Image File
  • Using V-Ray Raw Image File
    I was wondering if anyone else has run into this issue:
    I started to use the V-Ray Raw Image File because Rhino kept crashing when I tried to render a large scene (2700x1200). The 3dm file is 116mb. After I convert the VRImage to EXR, when I open it in Photoshop the image is washed out.
    - James
    Re: Using V-Ray Raw Image File
    Raw output images are saved with Gamma = 1,
    so in photoshop:
    Image > Adjustment > Exposure > Set your Gamma
      awesome! thanks so much!
        You should use the inverse of the gamma that you use in Rhino. If your gamma is 2.2 in Rhino, you should use 1/2.2 = .4545 in PS. Type .4545 for the gamma in PS.
        Best
