Maximum output size?
  • Maximum output size?
    Is there a maximum render output size.
    I can render at 3001 x 3001px but if I try for 3100 x 3100px it renders out black.
    I'm using QMC and light cache.
    Re: Maximum output size?
    It is limited by your ram, if you want a larger size, get more ram
    You'll probably find that if you render something extremely simple (i'm assuming this is a model in progress you've been trying) you will be able to render and much large sizes.. with complexity the size of what you can render is reduced.
      If you render to file instead of the Render Window you can render out larger images.
