re: serial number and no replies
  • re: serial number and no replies
    First I love VRay I am using it for my Masters project at Uni and though only a beginner - I love the results.
    However on opening Rhino on sunday I was informed that I had used my serial number the maximum number of times and needed to contact authorisation@asgvis.com. I know from past experience that this will take 5-6 working days.
    I have a deadline for Thursday and now will have to explain to my tutors why my work is not finished, and hope that I can still retrieve some kind of mark from it (not hopeful)
    This happened recently as well and I only knew all was ok on opening Rhino I received no notification from yourselves. I have also sent you two previous emails (about a connected issue)over a long period of time which you have not responded to.
    Is it because I am a student that you don't feel it's necessary to respond? Others seem to comment on the good service- what am doing wrong?
    yours very frustrated (pulling my hair out!)
    Re: re: serial number and no replies
    Hello Peta,
    Please try authorizations@asgvis.com
    We do what we can to answer this specific inbox within 24 hours when the question is activation related. Its the support@asgvis.com email address that is 2-4 business days normally.
    authorisations@asgvis.com does not exist
      Thankyou for that! thats English english spelling for you!
      however that still doesnt explain why I have had no replies to emails sent via your website to support@asgvis.com.
      But since this is where I get a response then I will post it here:
      when I reinstalled Rhino and vRay after my computer crashed, I needed to contact you to activate my authorisation code.
      However once I had reinstalled the software i got the following messages:
      rhino plug in error:
      rhrdk.10.v40.rhp Unable to load rhrdk.10.v40.rhp plug in : dependent
      DLL is missing
      rhinoceros 4.0 V-Ray for rhino
      Unable to locate or load RHrdk.10.v40DLL some functionality for our
      sunlight panel will not be available.
      I contacted you and rhino and rhino replied on 15.03.10 to tell me:
      We aren't aware of any current incompatibility between Rhino and Vray.
      To ensure compatibility, please uninstall both Rhino and Vray and do the
      following:
      - Install Rhino from your CD.
      - Install the last Service release (SR7:
      http://files.na.mcneel.com:80/rhino/...sr_en_20091214
      ..exe?AWSAccessKeyId=050NWYGC9TWYXMD9YG02&Expires= 1269258677&Signature=5e
      LfZxb%2bpy042XBXJM2J91f02h0%3d )
      - Install Vray using the last installer available (check with ASG:
      www.asgvis.com ). Don't install the RDK now.
      I then contacted you again to check whether I would need to reactivate vray on installation. Since i am very busy using it at the moment I did not want to wait the 5 days which it took last time to reactivate.
      I am still waiting for a response to that email, I believe I also sent a follow up email via the website to ask what the delay was...
      Once you have reactivated vray - I will still need a answer to the above issue.
      It would also be useful to know why my activation code is not working again?
      FYI I have the latest version of RDK and vray is version 01.05.29 (well it was last time I could check!)
      Thanking you in anticipation
        This error means that you need the latest RDK
        http://download.rhino3d.com/en/RDK/4...ease/download/
        Install that and you should be fine.
          Originally posted by alrami
          Hello Peta,
          Why not set up an alias of the email address?
            we have a couple redirects set up for some typos, I guess it can't hurt to have a couple more... We can only account for so many typos before it gets ridiculous though. The correct email address is clearly written in that error message.
            Devin Kendig
            Developer
            Chaos Group
