Trouble with Rendering
  • Trouble with Rendering
    hey 2 quick questions
    I am trying to make a good but quick render to be printed of a building i created.
    1. what option should i load that wont take an hour to render? I only need to print at 11x8.5
    2. It says it is trying to render but the time bar hasnt even started
    Beginning render sequence
    Preparing renderer...
    Preparing scene for rendering.
    [RenderView] startCameraTime=0.000000, endCameraTime=0.033333
    [RenderView] numCameraTMs=2, numFrames=1, frameSamples=2
    Initializing built-in VFB.
    Preparing camera sampler.
    Preparing scene for frame.
    Compiling geometry.
    Bitmap file "C:\Documents and Settings\fpedrogo.ASGVIS\My Documents\VrayRhino_Materials\Architecture\Untitle d-1.jpg" failed to load: cannot open file
    Exception: Compiling geometry
    Photon size is 56 bytes.
    Light cache sample size is 120 bytes.
    1 interpolation maps registered
    Rendering interpolation maps with minRate=-3 and maxRate=0
    Setting up 2 thread(s)
    Threads completed
    Threads completed
    Threads completed
    Threads completed
    Calling endPass() on irradiance maps
    Calling prePassDone() on irradiance maps
    Image prepass completed.
    Rendering image.
    It stops there. Have i done something wrong?
    one item
    Its trying to load an image that it cannot find; [C:\Documents and Settings\fpedrogo.ASGVIS\My Documents\VrayRhino_Materials\Architecture\Untitle d-1.jpg" failed to load] Is that image being used for lighting? It also mentions a range of frames, so verify that all animation settings (on or off) are in agreement.
    Since I move from computer to computer quite a bit, I always copy ALL map images into the same folder as the Rhino .3DM file.
      Re: Trouble with Rendering
      So I'm having a very similar problem with a "fpedrogo" material in my scene, but for the life of me I cannot find where it is. Is there an audit or some other way of isolating this thing and remapping it or deleting it? I'm using the latest VfSU and I've gone though all of my materials and all of the bump maps and everywhere I can think to look, any ideas?
      http://wworks.carbonmade.com
        I went through each of my materials again. I found the image referenced under my reflection-->fresnel-->perpendicular slot.
        Guess I didn't look hard enough :P
          Good to know that you found the missing texture. Let me know if you still need the texture, maybe I can find it on my hard drive.
          Best
