Hi
I have made a site model based on contours from a survey. So each contour was at the appropriate level and I extruded each curve creating a polysurface. I may or may not drape a surface over this to create a continuos surface, but its not really necessary as I'm just trying to quickly model the site and tree cover to get an idea of shading on site throughout the year. I made some simple trees, a cylinder trunk and a sphere for the canopy, grouping both for each tree, each tree is now at the right height. All the trees are in the correct location in plan/top view and I was wondering whether there is a way that I can project all the trees at once onto the appropriate contour surface below? I know the project command works for curves projecting onto a surface, wonder if there is a similar way that 3d object can be projected onto a surface below so it is not flattened but merely 'sits' on the surface below. Hope this makes sense and hope there is a better way. Also if anyone has any suggestions on how I might improve the above process next time round please let me know.
Thanks
Thanks
