Hi All,
I've been working on an image of a yacht underway. I've developed a number of images of yachts sitting placidly on a water surface. The effort was to make a boat move. The water surface I'm working on seems to have 3 elements.
The first is the base water surface, an infinite plane. No issue.
The second is the actual wake of the boat which I'm doing as two physical surfaces with something like a cloud material. What I've got so far is close (but needs improvement). Not the primary problem.
Adding the third element, however, has been a problem. These are displacement boats so the water around the boat has a sine wave shape that has to match the boat. I did a relatively small surface with that shape that fits ok to the hull. I wanted to fit that into the "infinite plane". I can cut a hole in the plane with standard functions, but the "infinite plane" seems to ignore that hole (which I'm trying to patch with the sine wave surface).
When that did not work I made my own surface (to replace the "infinite plane"). Not suprisingly I had to make a huge surface to appear "infinite" I also seemed to have a problem making the same material in the sine wave patch match that in the very large plane that I hoped to use to replace the "infinite ground plane".
I can add images.
Any thoughts?
chuck
I can add images.
Any thoughts?
chuck
