Making floor tile
  • Making floor tile
    Hi
    Is there a simple way to make a simple floor tile surface. In other programs I can add a color or a jpg to the"tile" slot and a color to the "joint" slot and then define the repeat of the pattern. I can make 3" wood planking or 4 x 4 inch wall tile simply.
    How do I do the same in Vray. I've got a wood pattern, but I need to put joint lines to make it look like boat decking.
    Thanks
    chuck
    Re: Making floor tile
    are you using 1.48? (i don't think this is available in 1.05, though could be wrong) - add a texGrid map in your diffuse layer. you can control line thickness, line & tile color, etc. with the different parameters.
    you can add the same as your bump or disp map, maybe with a little blur.
      Hi
      Thanks for the help,
      That seems to be what I was looking for.
      I appreciate it.
      chuck
