"Performance loss: dynamic memory limit too low"
  • "Performance loss: dynamic memory limit too low"
    Folks,
    when rendering large formats at reasonable high quality for printing, I've encountered following problem:
    Render progress window says, "Performance loss: dynamic memory limit too low".
    It happens in areas of complex geometry (--> displacement map) when computing the prepass, which is just one pass due to distributed rendering.
    Calculation comes to a halt and doesn't seem to progress any further.
    Which variables should I tweak in order to get it running properly? (using DMC and IM)
    Thanks guys!
    Cheers,
    Matt
    Re: "Performance loss: dynamic memory limit too low"
    Under the "system" rollout we have an option called "Dynamic Memory Limit" this option basically save memory for the dynamic geometry. Displacement is considerate a dynamic geometry so maybe you have to increase this value to save more memory for the displacement.
    Best
      Well, it just says Mem limit (I'm using 1.05.29).
      But when I increase the value, it seems to work
      Thanks a lot!
      Cheers,
      Matt
