VR Maker
  • VR Maker
    Hi All,
    I was wondering if anyone knew of a way to create something similar to GemVision's Matrix 3D Virtual Reality Maker (VR Maker)? Essentially it uses a series of curves you specify around your object and then specify the number of images to render on each curve and then takes those images and builds them into a SWF format.
    Any thoughts or suggestions would be greatly appreciated!
    Thanks,
    Michael
    Re: VR Maker
    Michael,
    Would you be looking to do this with Rhino/Matrix? If so the Vray for Matrix works with this function. If you are working in juat Rhino you might try the "SetTurntableAnimation" command. this is Rhino's version of the Matrix builder.
    "A Diamond's not a Girl's Best friend... Her Jeweler is." â„¢
      Re: VR Maker
      Thanks for the response. I suppose what I am really after is something that would allow me to render a number of images and then assemble them into a swf that has interactive capabilities. Matrix has this function built in and I'm trying to find an equivalent I could use with Vray for Rhino.
        Re: VR Maker
        http://forum.asgvis.com/index.php?topic=7692.0
        Devin Kendig
        Developer
        Chaos Group
          Re: VR Maker
          Thank you very much for the link. This helps!
