I am rendering an animation and am running through the pre-calculated irradiance map using the Incremental Add to Current Map setting. I am calculating every 5th frame of a 1200 frame animation. The first frame took a couple minutes, but every subsequent frame has gotten progressively longer, until now it is taking over 2 hours per frame. I was under the impression that the time should be getting shorter as it wouldn't have to re-look at previously calculated samples, but the opposite seems to be the case.
Also, though it is now taking over 2 hours to complete each frame, the time stamp on the image shows only just over 1 hour. It takes about an hour after the progress window shows Clearing mapping. Is this normal?
Thanks for any help.
