How to blend my groundlayer correctly with background
  • How to blend my groundlayer correctly with background
    I have an issue when using HDR images for background and groundmaterial.
    The reflection layer does that the edge of the ground will show in the render.
    Is there a way to avoid this? I tried using a gradient without luck.
    Or is this post render work. (i dont really have the skills)
    Se picture: (this one was better than most renders)
    Uploaded with ImageShack.us
    Roy Berntsen Design
    www.royberntsen.com
    Designing the future..........
    Re: How to blend my groundlayer correctly with background
    I dont think you wont ever be able to properly blend some of YOUR water of the water around. Just create a water surface that covers the ENTIRE water surface of the background.
      The fastest way it's to do a post-work with GIMP (opensource tools).
      It's very simple and I'm sure if you are able to draw such a boat you will able to learn GIMP.
      Another way it's using a gradient, or a B/W map, it the Diffuse>Transparency of the ground plane material
      hope this can help you.
      Riccardo
