Anybody with experience in renderin grass field using proxy?
  • Anybody with experience in renderin grass field using proxy?
    I'm using proxy for turf grass (80*80cm apr.). If I try to array it and get for instance 15*15m, it makes my render incredibly slow..
    What's the logic when using proxy? Should I repeat relatively small parts many times, or rather bigger parts less times?
    thanks
    V-Ray proxy is a dynamic geometry. I recommend you to use like 80% of all you memory for dynamic memory. Go to the System tab an increase the "Dynamic Memory limit". In my case I have 8 GB of ram so I use like 5000 on my Dynamic memory limit.
    Actually in the next beta build we changed the default dynamic memory limit to 5000
    Best
      cheers!
      thanks a lot
