V-Ray not running on v5 release?
  • V-Ray not running on v5 release?
    After installing v5 release, I can't seem to get V-Ray to work. When I try and switch renderers to V-Ray, Rhino reports:
    Command: _SetCurrentRenderPlugin
    Plug-in name or ID ( Rhinoceros ): e8cfe179-b60c-411a-8416-62a893334519
    Unable to make "V-Ray for Rhino" the current render plug-in
    If I look at my WibuKey server manager, I see:
    1 port scanned: 1 WibuBox at 1 port found.
    Table of supported clusters:
    Cluster 1: 250897:7758101 (unnamed), 1 slot
    - controlled by entry 1 of WibuBox 11-10435708 at USB: 1 slot
    Used WkLAN server name: Sam-PC - port: 22347.
    Used IP address: automatically detected.
    ### WkLAN server is active.
    General WkLAN timeout set to 1440 minutes.
    ### 0 WkNet processes started
    11.09 15:21:56:781: WkSvw32.exe is running.
    Any thoughts as to what is wrong?
    Thanks,
    Sam
    You have to go in rhino-tool-option-plugins and enable manually Vray the first time.
      Thanks Renee, it is enabled in Rhino Options -> Plug-ins (it is checked), but still fails to load. Re-drag and dropping it doesn't load either, just the same "Unalble to load VRayForRhino.rhp plug-in: could not open plug-in file or plug-in failed to start"
        have you tried reinstalling Vray with the exact same path Rhino5 is now installed?
          hi, do you have some plugins- like simlab or visualarq? disable simlab3d 3.x-and disable c++2010 during installation of vray 1.5- check after installation if vray is loaded in plugin-manager.
          all the best
          mackl
          marblepeak design
            I used VfR since a long time, installed Bongo 2 today and I got the same problem, VfR can't be loaded anymore. A reinstall of VfR helped.
