Material ID trough glass?
  • Material ID trough glass?
    at the moment I render watches and want to get masks for the materials behind the glass. Is there a simple way to get it working? If not, please set it on the wish list.
    Best-
    Micha
    Big PLUS for that,I need that very often,and do the render twice so I can get the mat ID
    Renee
      Does the alpha contribution might help you?
        not in my case
          No, helps not. I found a solution per trick, but I hope there will be an official solution. Could be there one, please?
            Hi Micha
            What about if you create a custom channel for that material, Then you can use that channel as the material ID for that material.
            Best
              Fernando,
              Can you explain please how to use those custom channels?There is some also for the lights,but it is not clear to me how to use them.
              Thank You
              Renee
                Fernando, thank you for the hint. So you mean I get the rendered parts cutout at the extra channel or is there a trick to get a mask on this way.
