I'm rendering a scene where I set the Irradiance map min/max to -5/-2
When I render the status window says Prepass 1 of 1 ... shouldn't it be more that 1 prepass if the setting is -5/-2 ?
Also, can I use a saved irradiance map on the same scene/view when rendering at double resolution or is it better to lower the min/max settings and generate the IR directly on the larger render ?
