GPU Acceleration
  • GPU Acceleration
    Does the "GPU Acceleration" switch actually do anything if Interactive rendering is set to off..?
    It is possible to run a production render on CUDA when the "Interactive" toggle is off, and the "GPU Acceleration" on.
    The only combination not supported is rendering buckets with GPU.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Ok, do you mind sharing some settings for this. Because nothing I do seems to get this to work, tried on 2 different older Quadro cards (K2000D and K2000) and a new GTX 1070.
      Only Interactive uses the GPU...
        Apologies for the confusion my last post might have caused. There is indeed an issue with CUDA falling back to CPU in Production render. This issue is currently getting resolved in the next upcoming build. In the meantime, I am afraid I cannot advise of any workaround except for using CPU for Production rendering.
        Kind regards,
        Peter
        Peter Chaushev
        Let's keep in touch
