Material Multipliers
  • Material Multipliers
    Hi there,
    I've been noticing that it is not possible to set the multipliers of a material higher than the value 1.0 since the last update. This is a real pitty because it was very nice to work with them, especially for reflections. I used to bring them up to 4 or 5 sometimes. Any workaround suggested? Or even better: might this feature come back in the next update?
    No response yet?
      Hello,
      This is an intended change to offer a workflow with more reliable output results.
      It is still possible to multiply a texture using higher values by slotting it within a Simple Mix texture (https://docs.chaosgroup.com/display/...INO/Simple+Mix) and adjusting the Multiply Result parameter.
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
        ok, thanks Peter
