Using two Rhino tasks at the same time?
  • Using two Rhino tasks at the same time?
    at VfR2 it was no problem to jump between several Rhino tasks at the same time, but now I get a license warning only. But often I'm working on complex files and I need to work on an other project for a few minutes. Closing my large Rhino files and reopen later cost me some minutes. Please allow to use several tasks at the same time at the same machine like in the years before.
    Best-
    Micha
    Looks like it should work, but some times it doesn't work. I suppose so it will be no so easy to fix.
      Hi Micha
      Could you please advise what the licensing error is? Additionally, could you please send the logs from localhost:30304 (https://docs.chaosgroup.com/display/...enseServerLogs) to support@chaosgroup.com
        The problem was that after I pressed the asset editor button nothing happens, no editor opens, no error message. If I see it again I will look for the logs. At the moment it works.
