Chose Render Source in VR Settings
  • Chose Render Source in VR Settings
    I end up rendering the wrong viewport all the time. You start a rendering, realize you need to tweak something, then re-render, wrong viewpoint.
    It'd be great if instead of having to select the render viewport before hitting render, we could select it in the VR camera settings. Maybe one could chose from the saved views, standard views or active view? I imagine this would also be a step into creating a more robust render queue
    I run in this limitation often too and miss to fix V-Ray to a specific viewport. Could be nice to get it.
      +1 Would be absolutely helpful!
        Hello monksalve Micha toniboni
        Thank you for the feedback! I will make sure to bring it up internally for discussion and evaluation.
        Zahari Ivanov | chaos.com
