UI with multiple Rhino Sessions
  • UI with multiple Rhino Sessions
    Hi, it would be nice if Asset Editor UI could keep the saved configuration with multiple Rhino sessions.
    I usually open two or more Rhino to copy objects, materials, work with blocks in the main file etc..., unfortunately only in the first the UI looks correct, in other sessions, configurations are reset to the initial/default state.
    So for example UI color and Slider Color Space are different, everything is reset to Basic instead of Advanced, but most important (for me at last) custom folders in library are not visible.
    I don't know if it's a Rhino limitation but i hope you could find a solution.
    Also, why the Global Illumination Tab stay always in Basic mode even though in the configuration everything should be Advanced?
    Thanks
    -Micha
      Could you please do something about this?
      Thanks
        Also I connect to my own material folder again and again, but after a few sessions it get lost and I need to connect them again.
          Hello, ALTO and @Micha
          Apologies for my late reply!
          I'm afraid after an internal discussion your the request to have per-session, per-project configurations was not deemed feasible. Currently, only the last modified session configuration applies globally. Changing this behavior was determined to cause too many edge cases which would disrupt user workflows more than simplify them. If there is anything else on your minds on this topic, please let me know!
          As for the "custom folders in library are not visible", Andrea, if you haven't yet reported this to our Support team, please do so via https://support.chaos.com/hc/en-us/requests/new and my colleagues will do their best to investigate the issue and assist you accordingly.
          Kind regards,
          Peter
          Peter Chaushev
          V-Ray for SketchUp | V-Ray for Rhino | Product Owner
          www.chaos.com
            ALTO, just to clarify i'm talking about having only one configuration per session, my own configuration for all opened Rhino tasks.
            A the moment, we have the custom one (last saved config) only in the first task, if i open another Rhino session the default settings are loaded, so any customization is lost (like personal folder in library).
            So, is it not possible to make my settings the default ones?
            Thanks
