reset curve color correction
  • reset curve color correction
    I wish a reset option, and if posible a save and load settings.
    Joaquín Laborda - www.trumdesign.com
    If you right-click in the curves window, you will get a menu, which has "load" and "save" options. Will take a note about the reset too.
      Thanks Vlado, other useful thing could be having a cross in the corner of the color correction window, to close it. Because if you close the frame buffer window, its imposible to close it.
        It's already done; also the color correction window now closes automatically if you close the main VFB window.
          OK, Thanks !
            so if one correct the curves
            is it just for viewing purposes
            or does it apply when saving the image
            does it save the image as in corrected state
              It saves with the corrected color state
