Isn't the fresnel function the same thing as a falloff texture?
isn't the fresnel function the same thing?
no it is not the same. Fresnell is dependant on the the IOR value. With falloff you can assign two colors and use a blend curve to control between the two.
For example, if you want an objects color to be dependant on the viewing angle, you need a falloff type texture to get control over the behavior.You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
