gamma correction
  • gamma correction
    Right now, the global gamma correction has moved to the global switches and has options for changing RGB values and LDR textures, which is nice. There is one more thing though that I think needs to be changed: the correction should be possible without affecting the VFB. So maybe it should be like this:
    gamma[input box]
    [checkbox] affect VFB
    [checkbox] affect RGB
    [checkbox] affect LDR textures
    You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
    Re: gamma correction
    Maybe a separate output gamma value, or a little linked button. That way the input/output gamma could be tweeked individually from each other.
      http://www.asgvis.com/index.php?opti...0&topic=1948.0
        cheers Micha, didn't remember that one
          I'm sorry - I'm sure I'm showing my ignorance here...but why would you want to gamma correct an image and not have the effect shown? I'm not sure I follow how that would work since gamma correcting would inherently effect the output - right?
          As for the input/output I do understand that request
          Joe Bacigalupa
          Developer
          Chaos Group
            I would like to separate it, especially when saving to exr / hdr / vrimg, in order to keep the output image linear. Then there is also the sRGB button to correct for monitor gamma in case I want to preview the output.
            edit: in addition, in order to change exposure in post it is better to keep the output linear rather than gamma corrected.
              Ok - so separating the input/output will solve that issue then - right? Or do you still need a "Affect VFB" checkbox?
              Joe Bacigalupa
              Developer
              Chaos Group
