often I need to rerender several areas of a rendering and it would be great, if per "shift" or "ctrl" additional areas could be defined. Also it would be great if the area borders could be moved for fine adjustment.
Sidenote: the new implemented region render is great, helps me a lot during render panorama images, where the Rhino function renderwindow doesn't work, the right area can't be found at the viewport. Thank you for region render.
Micha
Micha
