Save render output
  • Save render output
    It would be greate to rethink the way saving render outputs is handled.
    1. when I close frame buffer and start another render or close rhino the last render is gone.
    2. when I check "save output" in render options it is saved but then when i render once more and don't change files name the render is overriden over the old one with no warning.
    When I have to set more renders at once I now have to check for hundreds times if I checked savings outputs for every file and that everywhere are set difrent filenames.
    Maybe V-ray should create placeholder files for the ones that are checked to be saved so they can not be overriden when set together and/or change names by adding numbers to not override existing files?
    makebelievegraphics.com
    Think it is a good idea.
