V-Ray 6 for SketchUp, update 1.3 is now available!
This topic is closed.
This is a sticky topic.
  • V-Ray 6 for SketchUp, update 1.3 is now available!
    It can be downloaded here:
    download.chaos.com
    After installation, you will find more detailed info about the changes in the 'VRayForSketchUpReleaseNotes' file:
    Windows: %PROGRAMFILES%\Chaos Group\V-Ray\V-Ray for SketchUp\extension\
    macOS: /Applications/ChaosGroup/V-Ray/V-Ray\ for\ SketchUp/extension/
    Regards,
    Konstantin​
    Improvements and bugfixes
    • Cosmos is updated to version 2023.10.09
    • macOS: An issue preventing V-Ray from being used on macOS 14 Sonoma is resolved
    • macOS: An issue causing the last imported Enscape asset to override all other Enscape assets in the V-Ray rendering is resolved
    • Fixed an issue with Decal assets causing abnormal render times
    • Raw texture buffers stored in a vrscene file are now correctly imported by the V-Ray Scene Importer. This significantly improves the import of V-Ray Scenes exported from Enscape
    • An issue with SketchUp's colorization and materials assigned to faces is resolved
    • The auto-generated UI of unsupported materials and textures is improved in a number of ways. The number slider range and step is updated to allow more flexible edits, string parameter values are now handled, parameter labels are better constructed, etc. Note that unsupported items can be imported using the V-Ray Scene Importer or in a number of other unconventional ways
    • Enscape asset file paths are now successfully resolved on macOS
    • V-Ray GPU: An issue causing colorful artifacts when rendering scenes containing multiple objects with a Subsurface Scattering material with RTX engine is resolved
