V-Ray 3 for SketchUp - Now Available!
  • #16
    Originally posted by dusan_marcinko View Post
    What about gamma 1.0 and 2.2 workflow, what about linear or exponential workflow? How can I setup render for 32-bit post–production after default exponential correction with default setting I can't change?
    Hi Dusan,
    The color mapping mode is set to 'Linear multiply' gamma to '2.2' and 'Don't affect colors' is on.
    The 'sRGB' option is enabled in the VFB. If an 8-bit image is saved the gamma curve will be applied (embedded), while 32-bit images will be saved without it.
    This setup is perfect for 32-bit compositing and post production.
    Regards,
    Konstantin
    • #17
      Originally posted by Konstantin_chaos View Post
      Hi Dusan,
      Regards,
      Konstantin
      Thanks Konstantin,
      That definitely allays some of my fears, as THAT is the workflow that I have always setup in VRfSU given that it is the one that gives the MOST flexibility, especially so for a post production/ render element workflow.
      Really appreciate the input.
      Regards
      BrianB
      PS - I really should also say a BIG well done to the VRfSU team, although a few things have been a bit of a shock, it really does look like a fantastic release. I will be starting production of a new Lynda.com course
      for V3 next month so will let you know if I run into any important workflow issues.
      Check out Lynda.coms Vray Courses
      • #18
        Originally posted by Brian Bradley View Post
        Obviously these are not 'deal' breakers but the approach to UI setup in Max, so using basic, expert and advanced modes, seems MUCH more user friendly to
        your 'experienced' customers to me.
        I was hoping, with this release, UI is going to be like that.
        I think the biggest advantage of vray is that ui and options are very similar between platforms.
        • #19
          Originally posted by Peter.Chaushev View Post
          Swarm installer is available only for Windows. Mac OS machines cannot be used as render nodes (for now).
          Swarm UI is part of the NeUI for both Win and Mac OS, meaning distributed rendering can be initiated using both Mac OS or Windows machines.
          Hi Peter, does the above mean that as per previous releases we can use 10 windows machines via swarm as part of the standard release? Or do we need to purchase additional licenses to populate swarm? Its very confusing!
          From what I can gather it seems that there are no swarm nodes available within the standard new release which is incredibly disappointing for people upgrading when they are coming from a version which carries 10. As a small office of only 3 people there is no incentive for us to upgrade when it means paying to lose features. Its even more frustrating when the smallest amount of node licenses you can buy is 5!
          • #20
            Hello, LOAM,
            You should be able to upgrade any number of your current V-Ray 2.0 render node licenses. Same goes for purchasing additional ones - there is no minimum bundle size.
            The new V-Ray render node licenses can be used by any of our products, not just V-Ray 3.4 for SketchUp. My colleagues from the Sales team will be happy to answer any of your questions, I have already notified them. Simpy send us an email at sales@chaosgroup.com
            Kind regards,
            Peter Chaushev
            Peter Chaushev
            Let's keep in touch
            • #21
              Hi LOAM, you get 1 workstation license and 1 render node license with a single V-Ray 3 for SketchUp purchase. Email me and I'll help you get to where you want to be with your licenses.
              Corey Rubadue
              Director
              Chaos Group
              • #22
                Hi,Corey
                I don't know whether the trail build is the final release version or not. But some bugs like render elements(black skatter assests matID) still remain.
                EV slider is not comfortable enough than previous build
                In interactive rendering mode,group/Instances/nested group disapper from VFB when editing,at least some function like refresh interactive rendering can improve this situation IMO.
                Hope these bugs could be fixed in the next released.
                • #23
                  Hi,Corey
                  Again, I notice fur object disappear in Interactive Rendering sometimes,will there be a work around to fix it?
                  Add: when GPU accleration tick on
                  • #24
                    Hi Corey,
                    I don't have your email address, I have PM'd you on this forum. Hopefully that is ok.
                    • #25
                      V-Ray 3.40.02, the first official V-Ray 3 for SketchUp update is now available!
                      It can be download here:
                      https://download.chaosgroup.com/?platform=56&product=47
                      After installation, you will find more detailed info about the changes and improvements in the hot-fix, in the 'release_log' and the 'changelog' files:
                      ./Chaos Group/V-Ray/V-Ray 3.4 for SketchUp/extension/release_log.html
                      ./Chaos Group/V-Ray/V-Ray 3.4 for SketchUp/extension/changelog.txt
                      Konstantin
