Is there a way to get Batch Render's error report or Log?
  • Is there a way to get Batch Render's error report or Log?
    There is a report from my customer that Batch Render is not completed. (Customer is Mac User)
    Sometimes it works well, it's random.
    However, I will not reproduce it.
    User environment:
    macOS Sierra (10.12.6), SketchUp 2017 Japanese, V-Ray SketchUp 3.60.03
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hello,
    Does the rendering process get stuck at a certain scene and won't finish or fails to render or renders successfully some scenes and then just stops, thus halting the whole sequence?
    You can ask your customer to open the V-Ray Progress window (button is at the bottom-right corner of the VFB) prior to Batch Rendering and once the issue is reproduced, copy the whole progress log to a text file. If you need assistance with the issue, please send the text file over for examination at support@chaosgroup.com together with a short description of the issue. My colleagues will then be able to help you out.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Oh, by the way, there was a V-Ray Progress window!
      (A little hard to find a place to open button.)
      Thanks for the advice.
      I will check it and report it if I find a problem.
      oakcorp.net
      v-ray.jp
