Vray 3.6 for Sketchup - Render error. Help!
  • Vray 3.6 for Sketchup - Render error. Help!
    Reads:
    '[AppSDK:commit] Can’t modify renderer while asynchronously preparing to start rendering'
    This error message comes up at the bottom of the Vray frame buffer.
    In the asset editor, the red indicator shows suggesting that Vray is rendering.
    If I restart the computer it seems to resolve the issue once, then it stops again.
    Any suggestions, please? Very frustrating.
    Thanks!
    2017 MacBook Pro
    3.1 GHz Intel Core i7
    16 GB 2133 MHz LPDDR3
    Radeon Pro 560 4096 MB
    Intel HD Graphics 630 1536 MB
    This behavior usually occurs when switching fast between render states. Because V-Ray NeUI waits for the host app to tell it when the renderer is done, starting and stopping a render process rather quick can cause discrepancies in reporting render states.
    We could only suggest to be a bit more patient when a render process is initiated or ceased.
      Ok great thanks georgi- you’ve identified the cause. What’s the solution? Plus, why does it only happen on some files?
        The issue might be more evident in some projects due to their complexity.
        When initiating a render job, the bootstrap phase will vary (time-wise) based on the assets and all other information related to the project. In that respect, for example, if during the bootstrap phase the process is stopped and started immediately or shortly after, the issue could occur because SketchUp cannot report correctly the fast change in render states.
