There is something weird going on in V-Ray Next with Skatter and proxies
When using proxies, some textures are not at the right size when enabling the "Render only" feature in Skatter, but they are rendered correctly when disabling it (the instances are actually generated in the model).
I thought it could be related to the issue we already talked about, when a 2sided material and its base material have different dimensions in the SketchUp properties.
I made sure the multi-material, 2sided material, and base material have the same dimensions, and the issue persists.
This seems to happen only with proxies.
Here is how to reproduce:
- Open the Skatter Library
- Load "Trees 01" as Proxies
- Pick a host surface
- Enable "Render only", generate and render -> materials are bad
- Disable "Render only", regenerate and render -> materials are good
This makes us look really bad, as people think this is an issue in Skatter itself We've had quite a few people reporting this issue to us.
