Dirt tex in conjunction with mix(operator) render issue.
  • Dirt tex in conjunction with mix(operator) render issue.
    I think I've found a bug in Next when using Vray Dirt tex maps in conjunction with mix (operator).
    I'm tooling around trying to create some procedural surface streaks. When I initiate an interactive render the streaks do not appear at all until I tweak any variable at which point they appear.
    For standard renders it seems I cannot see streaks at all.
    these are CPU renders.
    heres a screen cap of the interactive render
    https://www.dropbox.com/s/odaej7r9fv...r1_lo.mp4?dl=0
    and of the standard render
    https://www.dropbox.com/s/izdvl2dcs4...g1_lo.mp4?dl=0
    thanks
    rob
    Hi robD,
    I can't seem to reproduce this by building an example shader from scratch.
    Can you please share the scene or a .vrmat file of the material that's causing issues?
    Regards,
    Konstantin
      Hi Konstantin
      heres a link to a vrscene file.
      for some reason I am unable to pack project anymore.
      thanks
      rob
      PS running hotfix 1
      Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
        Hello, Rob,
        Recreated the shader structure based on the .vrscene you've shared but was not able to reproduce the issue.
        Does an error message pop up when your project fails to export? Is there anything printed in the Ruby console?
        Kind regards,
        Peter
        Peter Chaushev
        Let's keep in touch
          Hi Peter, I’ll try it again, I usually hold the messages window open during renders but I’ll try with ruby console open too.
          inwas going to do a complete uninstall and reinstall as for some reason I cannot Pack Projects anymore (no file is output) or save render settings (immediate crash) so something screwey is going on.
          will let you know.
          cheers
          rob
            For assistance with the Pack Project / Save .vropt issue, please write an email at support@chaosgroup.com or send me a forum PM.
            Kind regards,
            Peter
            Peter Chaushev
            Let's keep in touch
