Edge Texture not working in Bump Slot
  • Edge Texture not working in Bump Slot
    Bashing my head against a wall for hours. Could be something I'm failing to do - but can't get the edge tex to work in a bump map.
    The goal, is to use the EdgeTex to create rounded edges on a box.
    No matter what I try, it doesn't work. It works fine in the diffuse slot - but not the bump map slot.
    Attached is a test file, that highlights the problem and a screenshots + render.
    Using the edges texture as bump is a special case in V-Ray and requires a custom mode of the bump map to be selected - Bump Texture Channel.
    Here is the effect when the correct option is selected:
    Regards,
    Konstantin
      Thanks. That works. Please update your docs. It cost me fruitless day of experimentation -- for what was a one line solution!
      s.
        The following info is available at the very beginning of the Edges texture overview description at https://docs.chaosgroup.com/display/VNFS/Edges.
        The texture can also be used as a bump map (Bump Texture Channel mode) to produce a "round corners" effect for mesh objects.
        I will pass along a recommendation to present this feature in a more illustrative way.
        Kind regards,
        Peter
        Peter Chaushev
        Let's keep in touch
          Originally posted by konstantin_chaos View Post
          Regards,
          Konstantin
          I'm beginner. Can you explain how I will do this process from start to finish? Or is there any tutorial?
            Hi ecati,
            Here's how you set this up:
            1. Create a Generic material
              Click image for larger version  Name:	round01.jpg Views:	0 Size:	213.2 KB ID:	1104906
            2. Add Bump attribute to the material
              Click image for larger version  Name:	round02.jpg Views:	0 Size:	211.0 KB ID:	1104907
            3. Change the Bump Mode to Bump Texture Channel
              Click image for larger version  Name:	round03.jpg Views:	0 Size:	223.4 KB ID:	1104908
            4. Add an Edges texture to the Bump Map slot
              Click image for larger version  Name:	round04.jpg Views:	0 Size:	235.8 KB ID:	1104909
            5. Tweak the Width of the edges texture to increase or decrease the rounding effect
              Click image for larger version  Name:	round05.jpg Views:	0 Size:	189.0 KB ID:	1104910
            Regards,
            Konstantin
              Hi Konstantin,
              Thank you very much for your reply.
              The main thing I want to learn is this; How can we get "Edge" under "TexBumpGranite"?
