Denoiser + Lens Effects
  • Denoiser + Lens Effects
    After hotfix 1 denoiser and lens effect "EffectsResult" element isn't blending.
    Happens with pre enable and default settings.
    Happening on all SketchUp models.
    Is this a known issue?
    Moshe Shemesh
    Architect | 3D Artist | ISRAEL3D
    Chaos Group Official Partner | V-Ray Israel
    Could you please provide screenshots to illustrate the issue and the settings used?
    In the meantime, you could lower the Threshold parameter and see if this produces the desired effects
      Thanks Georgi,
      The issue persists. Even when starting a new model, when using V-Ray Denoiser no lens effects can be applied.
      This was happening right after hotfix1 and I couldn't revert to the initial build due to the warning message implying things was made in a newer version, so I've sticked with the hotfix1 hoping for a resolution.
      Glare element is black. Effect result doesn't apply lens effects.
      Moshe Shemesh
        Would it be alright if you send us an sample project to further investigate?
          Please also see the screenshot below-
          Moshe Shemesh
            Hello, Moshe,
            Could you please toggle off the Lens Effects panel's "Load filter" and "Use Obstacle Image" checkboxes and see if this resolves the issue?
            Kind regards,
            Peter
            Peter Chaushev
            Let's keep in touch
              Originally posted by Peter.Chaushev View Post
              Hello, Moshe,
              Kind regards,
              Peter
              Thanks Peter I was able to regain control over the lens effects however it doesn't seems to be using the denoiser element. I'll try to work this out again and have you informed.
              Moshe Shemesh
                Success, all is good, it was the "Load filter" checked. Thank you!
                Moshe Shemesh
