Sketchup crashes when trying to update diffuse Bitmap of material or add bump/displacement bitmap
  • Sketchup crashes when trying to update diffuse Bitmap of material or add bump/displacement bitmap
    I have an tried to change the bitmap on an existing material i have in a project/i've lighten the diffuse image and want to reload. Also had issue when creating a generic material and then adding a bump/displacement to this material. Each time it crashes sketchup.
    Work around is to import the image as a texture and then apply the bump/displacement then, this seems to work.
    Is this a known bug or is there something I need to updated?
    Could you please provide some additional information?
    1. Does this occur with a specific bitmap texture? Are you able to consistently reproduce this in any project?
    2. What is the full version number of V-Ray (Extensions > V-Ray > Help > About)?
    3. What are the full specifications of the computer?
    4. Are you using any other 3rd party plugins?
