Hi All,
I'm getting a weird issue whenever I try to render an object with a transparent background. For instance, when I render a tree with a transparent background, I get a "halo" around the tree instead of a clean transparency (see attachments). I've made the sun background invisible. This halo typically is not an issue when only rendering 1 image because I can photoshop it out. However, I'm going to be rendering an animation with hundreds/thousands of frames so I'm not going to be able to edit every single one. Does anyone have a solution to this problem?
Thanks
Thanks
