transparency of glass with denoiser - smudgy material behind the glass
  • transparency of glass with denoiser - smudgy material behind the glass
    Hello,
    iam just courios, how to setup glass material, that would be not bluried so much after denoiser ? the material behind glass is after denoiser so smudgy. I use hybrid rendering Cpu+Gpu and what i find is to set up "affect all channels" but thi seems doesnt work. Only way i cant make good result is with render elements and for denoiser i use photoshop.
    Is here some other easiest way to get sharper material behind glass ?
    I think this is something, that bother many of us
    I attached picture with basic glass material.
    thank you
    Hello,
    Thank you for your question!
    Denoising what is behind a refractive object is a bit tricky. To avoid the smudginess you've illustrated, please make sure:
    • the glass material's reflection does not affect all channels
    • the glass material's refraction affects all channels
    This, however, would only help when using the CPU engine.
    Our dev team will be notified of this particular denoiser behavior when using V-Ray GPU.
    Kind regards,
    Peter
    Last edited by Peter.Chaushev; 07-05-2020, 09:50 AM. Reason: Removed GPU denoised output improvement, not viable.
    Peter Chaushev
    Let's keep in touch
      thank you for answer... i try it and it look better /rendered with cpu+gpu/
      it will be great, if you can manage to get better results in GPU rendering too .. because this way is renders very fast
      one more question, i see beta for 3ds max, and you have implemented lightmix....and brand new VFB window.. so is possible to get this feature to vray 5 for sketchup in the future ?
        Regarding a feature list of V-Ray 5 for SketchUp, all I can share at this point is it will contain some of the new additions showcased in the V-Ray 5 for 3ds max beta.
        Detailed info will be available once a V-Ray for SketchUp beta phase launches.
        In the meantime, any requests on new features and feedback on existing ones would be as always greatly appreciated!
        Kind regards,
        Peter
        Last edited by Peter.Chaushev; 07-05-2020, 09:52 AM. Reason: No denoised GPU result improvement vialbe at this moment. Removed original suggestion.
        Peter Chaushev
        Let's keep in touch
