HDRI Background doesn’t show up on render
  • HDRI Background doesn’t show up on render
    It is the second time I have this issue. I apply on background the HDRI file for background, set it up for an amount from 30 - 50 as always did but when try to render the scene the background is white. Can someone please help?
    Hi Iliada,
    You should check the following:
    - Decrease the exposure in the V-Ray Frame Buffer to make sure that the image is not just overbright
    Click image for larger version  Name:	vfb1.jpg Views:	1 Size:	77.2 KB ID:	1070626
    - Make sure that the HDR Bitmap texture placement is set to Environment Spherical
    Click image for larger version  Name:	image_57055.jpg Views:	1 Size:	49.8 KB ID:	1070629
    - If you're using a Dome light make sure that the light shape is set to Sphere
    Click image for larger version  Name:	shapeSphere1.jpg Views:	1 Size:	29.7 KB ID:	1070631
    If this doesn't help, please share a simple scene example.
    This way I'll be able to easily find the cause.
    Konstantin
      Hi, I am having the same problem, I have done the steps above still not a change. Not sure whether it matters that I am still using the trial version of SketchUp? I'll add a screenshot
        Hi mariya_ivanova​,
        The trial version is not limited in any way.
        Can you zip and share your test scene for further investigation?
        You can also use the Pack Project feature from the V-Ray menu.
        Konstantin
          HI konstantin_chaos
          Here's the .zip file.
            Hi konstantin_chaos
            Sorry it hasn't attached, you can download it from here: https://www.dropbox.com/scl/fi/7dnpy...mxvcaxktn&dl=0
              Thanks for sharing the project.
              The answer is really simple actually - spherical environments are not visible in Parallel Projection camera mode.
              Changing the camera to perspective shows that your setup is correct:
              If you want to see textured background in parallel view your only texture placement option is Screen:
              And to be honest I wouldn't recommend that since you'll have to separate the texture visible in the background and the one used for lighting.
              Screen projected textures produce incorrect lighting...
              Hope that makes sense,
              Konstantin
