Stain Mark on Render
  • Stain Mark on Render
    I have been working on a project and started rendering, everything was alright, and suddenly a mark that looks like a shadow comes up on the image.
    I have tried EVERYTHING. Turned all artificial lights off, natural lights off, made a new ceiling, repositioned my lights, changed global illumination from irradiance map to brute force... Nightmare.
    Can someone have a look at it and help me, please???
    Try turning hidden geometry on and delete if hidden lines appear on that area..
      Well, I checked that too and no hidden geometry on the way. =/
        Well, I have tried that as well. No good =/
          If you mean the ceiling then that is bad geometry without question. It looks like a boolean for those spots that has messed the faces up. Rebuild it with better topology and it should be just fine
          Or post the mesh and I'll look...
            I think so, bad geometry.. It doesn't affect materials without textures as far as i know but if you use texture map bad geometry causes issues..
              YEAH!!! Thanks guys!! The issue is sorted. I replaced the downlighters and ceiling! Thank you!!!!
                Good to hear. It's a common issue - once you know it you always avoid it
