Rendering will crash , Dragging files into the window will crash
  • Rendering will crash , Dragging files into the window will crash
    Hello
    When using SKETCHUP
    Sometimes rendering will crash directly
    Or it crashes when you place another file
    Then reopen the file
    The texture of the shader is not displayed properly
    Attach detailed information when MAC crashes
    Have been troubled for a long time
    No way to use SKETCHUP for 2020, 2019, 2018
    Because it crashes as soon as I use it
    Only use 2017
    Please help
    This article is translated using GOOGLE
    Anything wrong with grammar
    Apologized for any inconvenience we caused
    thank you
    Hello,
    Thank you for your post!
    Does this happen with a specific file or any?
    What is the full V-Ray version installed on your machine? You can check this under Extensions > V-Ray > Help > About.
    Is the issue reproducible when V-Ray is disabled from the Extensions Manager (Window > Extensions Manager)?
    Could you please record a video to better illustrate what is happening on your side?
