Hello All,
I have been communicating with Vizpark on an error/issue I am having.
Essentially, I am dragging proxies from the Vizpark download folder into my Skecthup scene. When I do this, I need to relink all the materials and meshes.
For some of the proxies, I have no trouble, for others, when the mesh is relinked the geometry "vanishes".
After they were able to reproduce the error, they said it had to do with the new V-RAY release and I should contact you for help.
Here is some background and some links to videos of the issue.
I am on MacOS 10.15.7, Sketchup Pro 2020, V-Ray next 4.2 (not sure of this, it's the latest version of V Ray for sketchup)
Please see these movies for examples of this issue:
https://www.dropbox.com/t/hLXMgsb54uaTN5np
https://www.dropbox.com/t/DWu9f9hfiEH9ykWX
Here is the reply from VizPark:
"thanks for the videorecordings of the issue. This really helped and I was able to reproduce the same error here.
Surprisingly the same issue happens on a PC (I thought it would be a Mac issue) with the new version of v-ray
42003 on both Sketchup 2018 and 2020. With the previous version 4.1 it all worked fine, so to me this certainly
looks like a v-ray issue which is new. I´d greatly appreciate if you could send this to v-ray support, so they know
about the problem. I will to the same and hope that they will find a solution soon. I haven´t tested the new v-ray
5 bets, so maybe that could be a solution. But for now it would also be important to fix this in v-ray 4.2, since this
is probably a version that a lot of Sketchup users use too."
I hope you can help, anyone else having this experience?
Bryan
Bryan
